Old 08-15-2002, 10:45 AM
Jeb's Avatar
Jeb Jeb is offline
I'm a bonehead!
I would suggest the 4.125 FRPP block with a 4" crank which you could use with 6.2" rods and still have a 1.25" compression height which should be plenty to keep the pin out of the oil ring and leave you with a 1.57 rod ratio which isn't too bad, if not actually desirable for higher rpm usage.
