Old 08-15-2002, 12:45 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Actually, blipping a cold motor can cause MOMENTARY spikes of oil pressure FAR exceeding the rated capacity of any of the coolers, which in turn can cause leaks. Aeroquip among others recommend use a check valve or a thermostat (which basically in this case serve the same purpose) with an oil cooler. Such check systems are also integral in most power steering systems to avoid the same type of problem, but from prople holding the wheel at full crank and hence full pressure. Name or brand has very little to do with it. Certainly Earl's has a pretty good idea of what they suggest having dealt with AN hardware for over 40 years.
Now, to get back to the original point, an acid bath would not be required as long as you clean the spot of failure very well by itself. In reality, is $150 worth the hassle and/or the loss of peace of mind?
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
