Trac-Loc
Hi, I think the replies are correct about the lube working its way in to the clutches and smoothing things out.
I did want to make a comment on the Ford 9" as I also have one in my Cobra. Its a great rear BUT something I didn't know (you might) is that if you ever plan on taking your car to the drags and you are going to use slicks be aware that IF you heat the slicks to get them to bite correctly your Trac-Loc is going to go away.
I ended up getting rid of the clutch type system and went with a Power Trax unit that has no clutches and is not a "locker". If your not going to take it to the track (drags) and use slicks then enjoy your 9" as it will probably last a long time.
Regards,
Bob
Johnex Cobra, Buick V6
