  #22 (permalink)
Old 08-15-2002, 11:15 PM
HPNUT HPNUT is offline
Hey, try a bigger fuse. But really, it sounds like you have a short somewhere, you probably already figured this out. If the pump cycles on and off ok and it's just when you start the Cobra then I would look at how it's connected to the ignition switch and if it's not to much trouble, replace the ignition switch. I'm saying to do this after checking all other obvious items like all fuses, all electrical connections, loose, or frayed wires, any "power" wires coming into contact with another circuit and or ground. The last part I'm sure you also knew. Just trying to cover all bases. I hope this helps.
