Thread: Liquid Lock?
Old 08-16-2002, 06:27 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default Liquid lock
Jeff et al,
Just getting back to this thread and wanted to answer some of your questions re: liquid lock.
My plugs on the left side of my engine are extremely difficult to get to because my steering column extends within one inch of my heads and plugs. Also, my #8 plug is very close to my firewall. Right side is a snap left side is a pain.
One other thing was that after I realized my problem I did lube all my cylinders while I had the plugs out and drained all my oil. A stuck carb float can really be a pain in the A$$. I also learned a long time ago to disconnect the coil wire when bumping the engine. I have hope this helps someone else on this site. As usual all of you Cobra guys are the best.
Clois Harlan
"Let's roll"
"Be part of Something Good
