Engineering upgrade to the CR/MII clutch cable setup. Used aftermarket BBK late ('79 - up) Mustang clutch quadrant, cable, and firewall adjuster. The cable is heavier, teflon lined, and longer so it doesn't get near a header and burn. The quadrant was grafted to the upper portion of the CR clutch pedal. Works like a Natilus machine arm, and keeps the cable at a constant radius. The nylon end of the cable fits into the firewall adapter. Used an aluminum standoff with the same mounting dimensions as the plastic MII piece, but won't break, or flex the firewall. Clutch end adjusts, and then sets in place with a jamb nut. Adjustments are then made from the firewall adjuster as the clutch wears.
Have shots if interested.
