Old 08-19-2002, 01:42 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
It's not necessary to change the bearings unless they are worn. Look at them when you pull the old cam. There shouldn't be any grooves or gold material showing. Most of the stock seals are the umbrella type. Most of this depends on the heads. Once you pull a valve cover you should be able to look at the seals to see which type you have.
Don
