Old 08-20-2002, 06:09 PM
GreyWolf GreyWolf is offline
Default 351 Cleveland Long Block Plus
'72 351C BLOCK - bored -.020", Fel-Pro gaskets, Moroso oil restrictor kit, alum "COBRA" "T" oil pan 7 1/2 qts.
ROTATING ASSEMBLY - KB pistons, Sealed Power rings, Clevite 77 bearings, Edelbrock timing chain machined for/with CompCams thrust bearing, Melling HV oil pump w/ARP driveshaft, Rhoads lifters, crank micropolished/oil holes chamfered, ARP conn rod bolts, alum Milodon HV water pump, StreetDamper vib damper, Crane RV type cam w/ARP bolt.
HEADS - 2V ported/polished, Crane rocker studs/guideplates, Crane valve springs/retainers/locks, CompCams alum 1.73:1 roller rockers, alum "351 CLEVELAND" tall valve covers, alum PCV.
ACCESSORIES - Edelbrock Performer int man, Accel dist, ARP s.s. bolts, MSD Heli-Core plug wires.
EXTRAS INCLUDED - ARP head stud kit, chrome bellhousing bolts, CompCams retro-fit hydraulic roller cam (284HR)/valve springs/seat cups/locators/shims/retainers.
PERFORMANCE - It has stock 76cc comb chamber heads still, with cam that's in it and a 600 cfm carb installed it does 404HP@6000 rpm and 416ftlbs@4000 rpm.
With the CompCams cam and a 750cfm carb installed, it does 482HP@6500rpm and 454ftlbs@4500rpm.
Both of these are with small tube headers w/mufflers and its current 9.5:1 comp ratio.
If heads are milled to give 10.0:1 comp and large tube headers w/o mufflers is used, the 750cfm/CompCams cam = 553HP@6500rpm.
I have full size picture I can e-mail you.
Cost me $5,767.98 w/o shipping
Sell $5,000.00 / make offer
