Thread: Cam Timing
Old 08-21-2002, 09:29 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
So the numbers you are measuring are not exactly what are printed on the cam card, how normal. This is why you must degree you camshaft, to get it timed correctly and to make sure it is opening and closing at the right times. The 5 degrees verses 2 degrees: 5 degrees on the crankshaft is 2.5 degrees on the camshaft, is that it? Were they giving that number in "cam degrees"?
