RZ, Sorry, I read your note to fast and missed the
oil TEMP! There isn't a specific place for the temp sender. Usually you need to cut a hole in the pan and weld in a bung to fit the sender. I don't know of any other spot on the windsor.
I usually put in all the fuses and both flashers, turn on the key and test everything. If there is a problem in a circuit it should pop the fuse.
Don
