Mike,
Is there a caravan (carasnake?) heading down from the Cleveland area? Would like to hook up with you guys for the ride.
Could meet at I-71 and 42,82,18,3,224,30???
HPNUT, you should have a VIN tag, if it is an EM, probably on the passenger side inner fender - will probably begin "EM427SC...". EM's also (typically) have large triangular glass panels at the upper corners of the engine compartment that hold the hood pins or a bracket for the hood handle. You should also have the cable bonded inside the door panel which releases the doors instead of the more correct door latch mechanism.
