Old 08-25-2002, 07:25 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default Roll Bar Harness Mount
I bought mine from Enzo at Finish Line. But since I have a B&B Mfg kit and my roll bar is a little wider than the average Cobra (15 1/2" wide center to center) I used Enzo's mounting hardware and made me a cross bar from 3/4" thich wall round steel. I made two tabs about 2" wide and 1/4" thick and positioned them on either side of my shoulders and welded them to the bar. I also drilled 1/2" holes in my tabs for mounting my shoulder straps. I may have them all chromed some day but for now I just painted them semi-gloss black and everything looks great and works even better. When I first mounted my shoulder straps I mounted them behind the seat my shoulder straps would slide off my shoulders in hard turns.
If your roll bar is 141/2" wide or less Enzo has a perfect set-up for you made with a stainless steel cross bar. If yours is like mine the modification is simple and works extremely well.
Good luck and happy racing.
Clois Harlan
"Let's roll"
"Be part of Something Good
