Jeb
You are absitively posolutley right about that firing order. It is possible to get all the same lift and duration and such from one of the available Crane cams without the HO firing order but not much point in it. My own opinion on this engine is that it is the generic engine with the cast pistons and the .379/395 lift roller cam and the E6SE heads. It's easier to tell if they still have the upper plenum on the fuel injection so's ya can see which way it is pointed. HO to the right and Non HO to the left. You can put the HO cam in it with max 1.6 rockers and a double roller chain to get rid of that plastic gear and still have a pretty hot and durable engine.
Craig
60 clicks West of Chu Lai
