Old 08-26-2002, 07:02 PM
Slide Slide is offline
It sounds to me like the front/rear bias is off. Get all four wheels up and have someone gently press the brake while you turn the tires by hand. The fronts should tighten easier than the rear. If you've been using the rear for your primary stopping, then they could overheat and glaze. Good luck
Clyde Blackman
