Old 08-26-2002, 07:37 PM
niles niles is offline
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Default TKO
Chaplin;
I think you might be getting a con job relative to the TKOll not being suitable for the street. the only difference, to my knowledge, is that the TKOll has a different grade of steel in 3rd gear and of course the .83 OD. Otherwise there the same and both will do fine on the street. Keep in mind if you use a 3.55 or higher rear end, the .68 OD 5th is about perfect for hiway cruising at low RPM,s. I got mine reg. TKO for $1200
gn
