Old 08-27-2002, 07:09 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
RZ, Yes, 130 on both sides of the amp gauge but, the wires can't end at the gauge, they have to be in a circuit that's drawing power.
What type of switch are you using for the headlights? I use a 3 position 6 pole switch and wire it as follows.
As you look at the back of the switch from the bottom I label the poles as 1,2,3 on the left and 4,5,6 on the right. #112 goes to pole 2 and 5, #171 goes to 1 and 3, #141 to 6, 4 is not used.
You only need double filaments on the front lights and the red tail/stop lights. The amber are turn signal and 4 way flashers, they only need a single filament.
The dimmer switch has the proper wires. # 141 is power and the other 2 are hi-lo beam.
Don
