Tie two bolts together with each piece of wire. Tension should be so that the bolt would want to tighten if the wire were pulled on. Get the pliers so you can twist it easily. Don't stretch the wire, and don't have it loose. Wire is cheap, if it doesn't turn out right, cut it off and try again. Watch for kinks in the wire, they will weaken it significantly.
