Mr. Fixit-
Do you think that even with all the torque of a 428 the .68 would be too low (is that right- always the confuse the low/tall) with a 3.31 rear?? I probably will never race, but would use a 5th as a highway cruising gear only? Alterntaively, if you wanted the .68 and used a 3.54 rear do you think the 3.27 1st gear of the Tremec would result in 1st gear being too short and result in excess wheel spin without a lot of usable power??
Thanks,
Mike
Replica is not a dirty word.
