Old 08-28-2002, 08:11 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
RZ, Yes the amp gauge will work that way.
You need to find out what type of switch you have. Usually a 3 pole switch is on,off,on. If that is the way your switch is then it won't work properly. If it's an off,on,on then it will work. Check it and let me know. You also need to check the dimmer and make sure the wires are going to the proper location.
Don
