Old 08-29-2002, 05:08 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default Dst Gear
Tommy,
You don't need to replace your dist drive gear all the time if you go with a steel gear that is made for a roller cam. Call Summitt or your Cam Mfg they sell them for about $50. I have installed a new gear on my dist before but for $15 I would have a machine shop do it for me. Some of these gears need a hole drilled for the roll pin and you really don't want to mis-drill your new gear.
Unless you plan on racing your car a lot and you may not want to use the brass gear.
Good luck,
"Let's roll"
"Be part of Something Good
