Old 08-29-2002, 09:12 PM
PNJSNAK's Avatar
PNJSNAK PNJSNAK is offline
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Jim: Got my washer double sided, adjustable jets from Finish Line. Drilled thru the cowl and because A & C 's fiberglass is so thick in that area had to back counter bore the underside of the cowl so there would be enough thread for the washer and nut. You can then adjust the angle of the jet independent or each other. Nice stuff, as always from those good folks at Finish Line.
Jim
OhioCobraClub.com
