Old 08-29-2002, 09:25 PM
cobrap51d cobrap51d is offline
Cobra Make, Engine: SPF 678
Send a message via AIM to cobrap51d Send a message via Yahoo to cobrap51d
Default Oil pressure fitting leaking
I'm chasing down what looks like a couple oil leaks. I found the oil pressure fitting on the block leaking a little (what would I call this fitting if I knew what I was talking about). Is it possible that this is the source of all my leaks. I'm finding oil mosly dripping off the bell housing.
Is there a replacement hose and fittings that are better than the one's I'm using. I have a plastic hose with copper fittings.
I believe there may be other leaks but this seems to be the furtherst forward and the highest.
678@myspf.com
