Old 08-30-2002, 09:42 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
It sounds too late now but I would recomend not installing the washer bottle and nozzle setup. They are not necessary. They do cause water spots on your paint if you do use them. I often removed the washer pump button from the dashboard and used that hole to mount the pull cable for onboard halon systems.
