Don't take a chance. Do a compression test asap...do not run it until you look into the possibility of WATER in the cylinders.
ALSO...be aware that
oil smoke sometimes looks a bit whitish to the untrained eye...either way, a compression test should get you the basic cylinder condition info.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
