Agro 1, If its white smoke, its water in the combustion chamber. You should be going thru plenty of water, so watch your radiator level. A compression test probably won't show you where the leak is because if it did you would feel it missing right now. A leak down will tell you for sure. If the leak down test is ok, then it could be comeing from an intake water passage leak into the adjacent cylinder. Under acceleration, it would suck water by the intake gasket but not at idle or cruise. This could explain why its only one side smoking on acceleration. If its blue, do not run that pcv back thru the intake. Your motor has too much crank case preasure(power) to polute the intake charge. Good luck, Scott.
