Old 09-01-2002, 10:54 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Seems to me that diff oil coolers are used on roundy-round cars all the time for the same reason. There is no heat radiating surfaces on the diff, because under normal use, they don't get that hot.
There are little trans oil coolers that come with electric fans that can be mounted in any position. Couple this with an electric oil pump, and a little plumbing and it should drop your diff oil temp.
Last time I visited the coatings shop, they were coating diffs with heat dissipating material on a race car, along with trans cases, oil pans, and brake rotors & calipers.
