Hi DV Perma-cool sells a maxicool in Summit or Jegs which will work. cames with a fan, all you need is a relay and switch to turn the fan on. Nascar sells a kit to run the pump off the rear differential. yoke when racing. Are you using
synthetic oil in your housing? Cobra restorer sells brake air kits for your brakes to get air on the rotors. Are your rotors drilled and grooved to help remove heat and tempature. If you are going to race this hard, maybe you need to go to outboard brake system. Good Luck Rick Lake
