Old 09-03-2002, 08:00 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
That is because you have the side hung float fuel bowls with an aluminum balance tube between them right? You can replace both bowls and floats with the center hung variety and then plumb inlets to both like the other Holley's you have seen. Each bowl with a fuel line running to it on the pass side.
