Old 09-03-2002, 08:08 AM
Dan Stryffeler Dan Stryffeler is offline
Cobra Make, Engine: Everett-Morrison, 347 Tri-power Stroker
Jack,
You've got to be joking! I never get any respect... probably had to be there to collect the trophy - just my luck.
Incidentally, made it home OK - stopped for groceries - then parked it in the drive. Pulled it into the garage about 10:00pm. Went out to go for a drive Monday a.m. and the clutch pedal went flat to the floor! Mixed emotions... made it to and back from the show (about 2-1/2 hrs drive time) and then it craps out... could'a been worse I guess.
Not sure what's up, will bleed it tonight. I have a McLeod slave (internal) - hoping the banjo fittings did'nt leak.
Mike, what's up with Wadsworth? can't recall hearing about this show.
Dan
