Old 09-04-2002, 01:46 AM
Rick Parker's Avatar
Default Fuel inlet location
Some of the OEM 4150 Holleys used on Ford HP applications had a hardline running between the front drivers side float bowl down to the fuel pump I believe the Fuel inlets were threaded on each side of the bowl, the passenger side had a 5/16" tube connecting the rear bowl with the front one. That was the OEM way of doing things, instead of a conventional duel inlet configuration.
Rick
