Old 09-04-2002, 03:28 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Beware, rollbars often will not swap between spf cars. They are numbered, like the hood and trunk hinges, because they don't interchange all the time between all spf's. Fortunately, if you loosen the two mounting bolts on the hoop leg closer to the passenger (13 mm socket and a long extension) you can get it to fit then tighten up those bolts.
