Old 09-05-2002, 11:00 AM
Ron61's Avatar
Ron61 Ron61 is offline
Default Re 351 pcv valve
Jeff,
When you made your road draft tube setup just how did you run it ? My 58 Ford with the 332 PI motor had a metal one that came up the back of the engine and plugged into the back of the intake but I can't remember just where. I hadn't thought about making one and running it to one of the breather caps as I now use a carb. and the pcv valve to get rid of the pressure. Your solution could cure what a guy I know is having happen and he refuses to use a pcv valve because the hose looks hokey so he has oil all over.
Ron61
Ron Widener
