Old 09-05-2002, 02:22 PM
Jeff Hamilton Jeff Hamilton is offline
Default FFR 3039 For Sale
2002 FFR Cobra Replica
Viper Blue With White Stripes
Chrome Roll Bar & Quick Jacks
Silver Ceramic Coated Side Pipes
Frame Painted PPG Sparkle Silver
P.S. Engineering 5 lug Halibrand Replica Wheels
B.F. Goodrich Radial T/A’s
Finish Line Wing Windows
Sun Visors
Roller Bar Grommets
Louvers
Hidden Trunk Hinge
Hood Hinge
Curved Trunk Hoop
Ford Morotsports 392 Crate Motor
430 Bhp @ 5500 RPM
450 ft/lbs of Torque @ 4000 RPM
9.7:1 Compression
Ford Racing Aluminum GT-40 Cylinder Heads M-6049-X303, & GT 40 Valve Train
Ford Racing High Performance Hydraulic Roller Lifter Camshaft (Valve Lift is .566” 232 Duration) and Roller Rocker Arms
Single Plane “Victor Jr.’ Intake Manifold M-9424-V351
New Heave Duty 5.8L “Sportsman” Race Block, Oil and Water Pumps, Dual Sump Oil Pan, Steel Billet Flywheel and High Performance Harmonic Balancer.
Custom Built Cobra Oval Air Cleaner With 3” K&N Filter
750 Holley HP Carb
MSD Ignition 6AL Box With Rev Limiter
Blaster II Coil
MSD Distributor
4 Into 4 FFR Headers
Holley Mechanical Fuel Pump
March Alternator Bracket
Serpentine Belt Set-Up
Tremec 3550 5-Speed
Centerforce Dual Friction Clutch
D&D Positive Stop Shifter
Lakewood Drive Shaft Hoop
8.8 Rear Axle Narrowed 4”
Mosier Engineering 5 lug Axles
3:55 Gears
Autoweld Adjustable Upper Control Arms
FFR Tubular Lower Control Arms
Aluminum Radiator
Automatic Cooling Fan With Manual Override
Optima Battery
Batter Cut Off Switch
Batter Jumper Posts
18:1 Manual Rack
Breeze Aluminum Offset Rack Bushings
Sweet Steering Joint
Power Brakes
Custom Door Panels
Classic Instrument Gauges with 180 mph Reverse Read Speedo
Tri State Heater
Russ Thompson Self-Canceling Turn Signals
Took this thing to the track 1 time and the third run ran 11.72 @119 mph on Radial T/A’s
$39,500
Car is located in Vermilion,Ohio
440-967-4429
