Old 09-06-2002, 06:53 AM
acaskie acaskie is offline
Cobra Make, Engine: Unique FIA 351 W
Neutral
Given the drivetrain power loss, you are around 365 HP at the flywheel. As I recall, the original motors running 48 IDAs and 12:1 or so on the compression with heavily ported Hipo heads were making around 380 HP-- I don't have the cam specs. So you're probably in the right neighborhood.
I have a mild 351 with 48 IDFs, 9.25:1 compression, .477 lift and iron GT-40 heads. In current tune it makes about 330 HP at the flywheel, with a bit more possible.
In all, I would think you're pretty close to where you ought to be.
Allen Caskie
