Actually CalMetal told me a trick for setting them right...you have to get them close and then run then and read the plugs...check to see which cylinder is burning the best...
Then you use a laser temp meter to measure the temp of the header for the cylinder that was burning good....adjust the other carbs to get the same temp on all 7 of the other exhaust headers...
Other than an O2 sensor in each header I don't know what you will get from the setup you have.
Matt
