For 15" wheels, the most brakes you can put on your fronts are Stainless Steel Brakes 4 piston calipers on Grenads 11" rotors. They should be able to re-drill the rotors for 4 lug bolt pattern. The calipers are actually newly manufactured Kelsey-Hayes calipers as used on '66 & '67 Mustang GT's. They work great. Kit is $695.
Now, if you have 17" wheels, by all means, go to Baer and check out their 13"front/12" rear caliper/rotor setup.
