Roscoe,
Have you needed to add any coolant to the car? I would also change the
oil!!!!! If you are getting no white smoke out of the car and it is a head gasket the water is going somewhere.....into the
oil..
I had the same symptoms when I blew mine..I could idle all day long but when I drove it the temp spiked..when I drained the
oil to check it I had ohh about 2 gallons of coolant in with the oil..
I hope you don't because it required the engine be rebuilt with new bearings....
Good luck.
Matt
