Old 09-09-2002, 06:39 AM
Hank Dondero Hank Dondero is offline
Thumbs up FFR 1776-II For Sale
Here is all the details of FFR 1776-II:
Vehicle is street legal in Massachusetts with VIN and Title obtained in 2002
Spec Racer Frame with IRS Option
3 Core Griffin Custom Aluminum Radiator
Fuel Safe aluminum fuel cell w/FMS 190 LPH fuel pump
Tremec 3550 road racing version transmission
Shortened and balanced drive shaft (new)
Battery relocated to RF cross member location
SUSPENSION
Front and Rear Sway Bar and Attachment Arms (Fronts connected, rears installed, not connected).
Front - 800 Lb Hypercoil Springs and Bilstein Shocks (Custom Valved)
Rear – 500 Lb Hypercoil Springs and Bilstein Shocks (Custom Valved).
Front Tubular Front Lower Arms
Front Adjustable Upper Arms
Flaming River Steering Rack w/Intermediate coupling Assy. & Aluminum Bushings
One piece upper steering shaft
IRS installation with FMS aluminum center section w/3.73 gears
Poly mounts for center section
Poly bushings in knuckles
Upgraded steel rod ends and washers for swivel points
BRAKES
Cobra “R” master cylinder (SN95)
Cobra “R” front Calipers (SN95)
13” Cobra “R” front discs cryogenically treated (SN95)
Cobra “R” rear calipers (SN95)
10.5” Cobra “R” rear discs (SN95)
Lisman adapters to mount Cobra “R” calipers to IRS knuckles
SS braided brake lines all around with metal feeder lines
ENGINE
Ford Racing M-6007-XB3 crate motor
Engine rated at 345 HP
Holley SyteMax setup – Upper and lower intakes
Aeromotive fuel rail system
30 lb injectors
SS braided fuel deliver/return lines
65MM throttle body
Custom MAF meter
FMS ceramic coated 1 5/8” headers
Solid motor mounts
Lakewood scatter shield
Aluminum billet fuel filter adapter
Oil cooler
Accusump
SS braided AN-10 oil lines
MSD Billet distributor
MSD AL6 ignition system
MSD coil
MSD wires
INTERIOR
14” road race wheel with quick release
Autometer Phantom gauges (oil temp, oil pressure, water temp, tach, speedo, fuel level, battery voltage)
Autometer shift light (Pencil style)
Autometer TriAlert (Monitors oil and water temp and oil pressure)
Autometer large red trouble light
Fire suppression system by SPA. (Water based system with 2 nozzles)
Kirkey Road Racing seat
WHEELS AND TIRES
Street tires – Yokohama AVS Sport mounted to FMS Cobra “R” 17” wheels
Race tires – 8 Hoosier R3S03 road race tires mounted to FMS Cobra “R” 17” wheels
MISCELLANEOUS
Extra set of Cobra “R” front calipers, rotors and spindles
Have stock front and rear springs and shocks
Tonneau cover
Asking 32,500.00
Hank
FFR 1776-II
