09-09-2002, 08:21 AM
TX
Cobra Make, Engine: Lone Star Classics #89 Keith Craft Genesis 427 so, stroked to 482, 649 hp. Sabre GT 40 #16 351W stroked to 408, 527hp, TWM stack injection, Fast XFI, G50/50.
Hey RockSnake,
I ran the Holley Projection 900 for about 2 years and would never recommend it to anyone.
Which type do you have? Are you tuning using the control box or a laptop. If you have a laptop there is a section that will help you set your TPS. If you have the control box you must set it by voltage output.
Beware: If you have the control box and save the current map the rev limiter is set to 2x the running RPM when saved. might you have been at 1250 when you pressed save? If you have the laptop there is a section to set the RPM limit.
I am by no means an expert but unfortunatly I have messed with this stuff quite a bit as I had to run an open loop with the Holley. Shoot me an email if you want and I would be glad to do what I can to help out.
If you have the hook up for the laptop but do not have on I still have the holley program loaded on mine (if it still boots) and could let you borrow it.
Just in case I have a slightly used Holley 750 w/elec choke. I'll make you a good deal on it.
John
