Old 09-10-2002, 09:15 AM
jams's Avatar
jams jams is offline
Cobra Make, Engine: B & B
Default Gas Tank Problems
Hi Guys,
I am having a problem with my gas tank and I was wondering if any of you had a similar experience or possible solution.
The driver's side top of my gas tank is caving in. The driver's side bottom is bulging out. I suspect that the bottom bulging is deforming the top and causing it to cave in. I noticed there are only 2 straps supporting the gas tank from below but there is a spot for a third. I am going to add a third strap and that will hopefully fix the problem. I also thought it was a venting problem but the vent seems to flow OK.
Anyone had a similar experience, possible solution? Am I missing something? You might want to take a look at your tank just in case.
Thanks Jim
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
