  #36 (permalink)
Old 09-10-2002, 08:44 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Ernie,
Smokey de-stroked the chevy 427 only for one race; He didn't win.
Chevy de-stroked the 327 to 302 only because they had to, to meet the trans-am max displacement of 5 liters, which is somewhere around 304 ". Pontiac experimented with a 303" engine, 4.12" bore with 2.8" stroke, but it never worked out. They ended up using the chevy 302 in the firebirds, with the smaller bore and longer stroke.
If you take a 289 and stroke it, you get a ford 302. If you take a ford 302 and stroke it, you get a 351. So, a 351 is nothing more than a stroked 289, with a higher deck height. The block has the same bore and bore spacing. I guess all those NASCAR wins with ford engines are with stroked 289's.
A Snake,
I was brousing through a ford web site, and they were talking about cast cranks being softer, or holding a better film of oil than a steel crank, something about the surface. Just what some serious drag racers were seeing at the drag strip. People spinning bearings always seemed to be running steel cranks.
Regarding the 406, yeah, they were all race engines, solid lifters, but I think all the blocks had the oil galleries cast in them, so they could have been drilled to run a hydraulic cam, like the 390's and 428's. The 427's from my understanding had a different casting process, and then were machined on a separate line than the other FE engines
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
