  #24 (permalink)
Old 09-11-2002, 11:40 AM
cobrashoch cobrashoch is offline
Cobra Make, Engine: Home built, supercharged 544cu/in automatic
750HP - RE; Pro gears - I'm no expert but I think it has more to do with the angle the gears are cut and the radius the teeth are. (more straight cut?) I didn't know pro gears are softer to. All I know is at ratios over 430 on a 9 inch ring gear there sure are a lot more smaller teeth and in my case the wear went away with the pro gears. Take DV up on his offer. If you don't I will pay a visit to his shop soon and we will have a community rear end out there!
Excaliber - Be carefull when buying this rear end as there are many styles of lockers out there that have close style names. To make matters worse the tru-trac is sold under several different names too!
cobrashock
Ron Shockley
