Thread: Lifting points
Old 09-12-2002, 12:02 AM
A Snake A Snake is offline
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
Michael,
I suggest using the "Cherry picker" again, but this time ask for a spreader bar that is set up to accept a chain with hook in each end.
Using the intake manifold bolt holes (without manifold) bolt on an "eye plate" to the front and another "eye plate to the rear. Right or left doesn't matter as long as they are diagonal across the engine. Make VERY sure you use all of the threads in the bolt hole in the head.
Now, you engine will pivot on the center of the spreader bar and the hooks and chain from the ends of the spreader will allow you to reach bottom without hitting the car's body. Most are adjustable.
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
