  #27 (permalink)
Old 09-12-2002, 12:47 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
I don't think it's a crankcase pressure problem. Aftermarket crank + 2 piece rear main seal = territory marking. Cut the block for a 1-piece and no more leaking from there. If you have oil blowing out your breathers and making a mess all over the valve covers, you have a ring seal problem.
