Craig,
I have not read the 3 full pages.. but hopefully you have decided NOT to use a locker or a spool. Im with DV.
Lockers do not belong on short wheel base high HP cars when used for the curves. You have to be a very good driver to make it work and be safe at the limit.... and I dont believe you can with your chosen rear suspension setup.
If I remember correctly, you are running the Stock FFR rear suspension now that you have decided against the IRS stuff.
That combined with a locker or spool and your HP level will most likely get you hurt. I am not kidding... or exagerating. If you push that car in the corners, it will bite you.
You have huge HP and now have the decided on most ill handling FFR rear suspension option.
Dont mean to spout off or come down on you.. .. BUT there a number of folks giving advice I just dont think is sound for your situation.
Peace,
David
