Old 09-14-2002, 08:08 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Years ago, Craftsman used to make die grinders with variable speed control built in. Many Pontiac, and Oldsmobile heads got ported with it.
Variable speed control is essential, and I never use one flat out.
My trusty old Craftsman gave out on this Cobra, and I had to replace it. Got the DeWalt from Grainger, and found a router speed reducer from a tool shop on-line.
Have never used an air die grinder because the electric one works so well. But using one is an art, like welding.
Need carbide bits of varying coarsness, and 3/8" is usually the only size I use. Use these on cast iron. Flutes will clog on aluminum. For aluminum, and brass, you need the non-ferrous bits. Flute pattern is entirely different, and bits are usually tool steel, rather than carbide. These bits work great on fiberglass also.
