Jack21, You're right about the long shanks. The only time I use long shanks now is with sanding cones on long spindles. Yes, I've had them grab and bend a spindle.
Chicks LI,
FYI, when you get done with the heavy shaping with a burr, you might like to smooth it up a bit. The same place you get the burrs will have the mandrels and sanding cones for fine work. I say "cones", but they come in all sorts of shapes. You can also get what are called "mounted points" Those are miniature abrasive stones, mounted on a shank. Remember this little piece of info when selecting mounted points: "The harder the metal, the softer the stone." Also, get a little dressing brick to "clean" the stones with. They will "load-up" with metal and dirt. When they start to get shiny looking, its time for the brick. You can also shape a mounted point with the brick or a mounted diamond dresser.
This is all probably a lot more than you need for the job you're trying to do, but it may help with future jobs.
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
