Tokico standard mustang shock
Well, i was just under the car yesterday and did the spring install, was a little easier once i saw the shock had to come off for full drop. the new springs went in well, and i noticed the shocks were plain white. how do you know if i have the SM600. any way the factory shock setup for rear is not the same as this setup, both ends of the shock have a bolt thru designs the original as a end bolt tip. so this is a no go. the shocks did help with some rubbing but still have some on the hard bumps, just on the driver side, I may consider cutting our the inner fender cover and raising the height over the middle section. Don, is this part removable . it looks glued at the edge. i was going to cover the section with a higher curved piece and rivet it to the inner fender area thus giving me more clearance. just some ideas. thanks Mike
Well officer.. It was like this.
