Kirby-
Yes, I did bleed both sides of the cailper as well as the bottom 2 bleeders. I tried the vacuum method as well.
H dog-
The brakes are bled and I guess the ultimate test will be when I go for the first hard stop. Probably in about 1 month.
What I did was exchange the clutch and the front brake master cylinder, they are both identical but Willwood seem to think that maybe I had a defective master cylinder and when I exchanged the two I got a better pedal so I am leaving it at that.
Alan seemed to think that when the rear brakes are hooked up with the balance bar and brake bias is adjusted that the car will stop well. We'll see.
Thanks for the replies.
Joe
