Thread: Lifting points
Old 09-17-2002, 12:42 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
If you remove the crank knob from the tilter, you can weld the nut onto the shaft, then just use a 3/4" air ratchet to tilt either way. I like to have the crank towards the frontof the car so it won't hit the firewall, but whatever works for you.
